SailNet Community - View Single Post - Autohelm ST4000 Plus problems
post #23 of Old 10-16-2012
Silvio
Battered and Bruised
Silvio's Avatar
Re: Autohelm ST4000 Plus problems
Originally Posted by CaptainDan99 View Post
The two halves snap together. No bolts or screws. Use several large screwdrivers a few inches apart and twist the screwdrivers. The two halves should pop apart. If the belt is shreaded, carefully check the pinion gear that drives the belt. The wires inside the belt can cut into the gear and ruin it. Early gears were plastic and often crack.
Hey CaptainDan99, I was hoping you would jump in here.
Thanks!
SV S.S.R.I
It's my happy pill
Silvio is offline
