SailNet Community - View Single Post - Optimal propulsion system
post #77 of Old 10-18-2012
Stumble
Re: Optimal propulsion system
The problem with towed and shaft generators is they require a boat that can maintain high average speeds thru the water over long periods of time. Most of these generators require a boat speed of 5kn to start working and only become really powerful past 6. That doesn't sound that bad, but they will also cost you roughly 1/2 a kn of speed while operating.
So unless you are consistently cranking out 130+ days you just aren't going fast enough to use them. And while I know many cruisers have hit that mark once or twice, not many can do it day after day reliably enough to count on them for power generation.
Greg
Stumble is offline
