SailNet Community - View Single Post - Mast wiring strain relief
post #5 of Old 10-19-2012
chef2sail
chef2sail's Avatar
Re: Mast wiring strain relief
The only problem with tieing themn together is if you have to work on one of them while the mast is up. I suggest you find a way to run the wires through a pvc conduit which you have attached in the mast.
It is a perfect time to also put a junction box in if you havent already so in the future when the mast comes down, everythi8ng is a quick disconnect.
Also use this time to run at least one or two messanger wires down the conduit permanently for future use.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
