SailNet Community - View Single Post - what do you keel bolts look like?
post #16 of Old 10-19-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: what do you keel bolts look like?
Originally Posted by SlowButSteady View Post
Hey. Those aren't stainless steel bolts, are they? I was told that SS on an iron keel was a no-no.
Yep, they are electropolished S/S, coated with anti-seize before installation.
The pic of the rotten stuff I posted earlier shows what happens to regular steel bolts. I did a lot of research for that very reason - the conventional wisdom is no S/S in an iron keel. I discovered that the big Euro builders all use S/S in iron keels. Due to that and the fact they can be easily pulled and examined, I decided to go that way.
Also, I've never heard of an iron keel with S/S bolts falling off due to crevice corrosion, galvanics or anything else to do with the metals, just a lot of talk about how "dangerous" it was, none of it by the way from anyone who actually OWNED an iron keel.
However I HAVE heard of iron keels mounted with steel bolts falling off - one of them was another Columbia 43 in Sausalito.
SloopJonB is offline
