SailNet Community - View Single Post - Simple electrical panel
post #9 of Old 10-19-2012
Sumner10
Sumner10's Avatar
Location: Utah (House & Macgregor 26 Classic) -- Florida (Endeavour 37)
Re: Simple electrical panel
I can't find just switch panels and called Blue Seas and another place and no one seems to make them. They all have fuses or breakers with each switch and a lot of times still incandescent indicator lighting.
I used the....
...Blue Sea fuse blocks like above in the Mac and I'm also using them in the Endeavour. I basically have each circuit fused with the fuse blocks (12 circuits on the one boat and 18 on the other).
I think it is redundant to go from them to a switch panel that then has another fuse or breaker associated with each switch. I also want LED indicator lights. This means make my own switch panels unless someone can give me a link to reasonably priced switch panels with LED indicators and no breakers/fuses in them.
Of course then the other problem is the common buss bar in them ,
Sum
Our 37 Endeavour --- Our 26 MacGregor --- Trips With Both
Sumner10 is offline
