SailNet Community - View Single Post - Yanmar 1 GM will not start
post #4 of Old 10-21-2012
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Re: Yanmar 1 GM will not start
If you have good compression (around 20:1), and it seems to crank at a reasonable rate, and still won't "catch" at all, about the only thing left is the fuel system. Assuming that you have bled the fuel lines, I would check the injector first then the high pressure pump. If it seems to "almost start", as in it catches for a second or two but never really gets going, you might have some sort of a restriction in the exhaust (but I doubt it).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
