SailNet Community - View Single Post - Microwave and gen.
post #6 of Old 10-22-2012
Jak
Just remember, is you go with the batteries/inverter solution, make sure the inverter will handle the watts, or you will be in the exact same spot. Look on your genny, most have 2 numbers, the 1000w is peak and not generally what it will put out (espcially if it is a Harbor Freight or made in China model, which also tend to burn out under hard use just when you need them most... )
adventures in the Puget Sound aboard my 1975 Aquarius 23'
Jak is offline
