SailNet Community - View Single Post - Quality of boats that sit vs sail
post #4 of Old 10-22-2012
capttb
Re: Quality of boats that sit vs sail
2 years ago I bought a 10 YO boat with 200 hrs. before that had a 9 YO with 400 hrs when purchased.
The boat with 400 hrs & a Perkins needed a new exhaust elbow (clogged), thru hulls may be stiff, if Marelon make sure they open/close without breaking. Lower furling drum if not used/flushed may be frozen, especially early model Schaeffer 2100 that do not have holes for flushing at top of drum.
Should do an engine service and impellor change asap of course, most things with bearings (sheaves, blocks etc.) will be dry and dirty and need flushing and lube. Check for cabin top leaks at chainplates and other cabin top mounting points. Sails and running rigging will be dusty/dirty and need cleaning, marcerator pump may be frozen from non-use.
Batteries at 10 are getting a little toward elderly also, check for water, I've found them bone dry and still starting an engine.
"Just call me TB"
capttb is offline
