SailNet Community - View Single Post - Lower shroud tension thoughts
post #11 of Old 10-24-2012
chucklesR
chucklesR's Avatar
Re: Lower shroud tension thoughts
Loos gauges and pre-tension guidelines are for when you are dock side, not when you are sailing. You set them dockside, then go sailing and check.
As KH said, loose but not floppy, mast in column. Actual tension then doesn't matter unless you are near breaking strength (not likely).
chucklesR is offline
