SailNet Community - View Single Post - VHF Output
Thread: VHF Output
post #13 of Old 10-25-2012
tibtib
Re: VHF Output
There may be a problem with the cable that you are using between the radio and your antenna meter. I suggest that you try another jumper cable. If the reading is still low, you should consider the possibility that your meter is not working properly. Borrow another meter from someone and compare readings.
tibtib is offline
