SailNet Community - View Single Post - How Hard To Push My Perkins
post #4 of Old 10-27-2012
jrd22
Courtney the Dancer
jrd22's Avatar
Re: How Hard To Push My Perkins
You'll need to know what the WOT (wide open throttle) rpm is supposed to be so you can determine if you are correctly propped/pitched. A Perkins dealer should be able to give you the correct max. rpm and the max. recommended cruising rpm (sorry, I'm not familiar with that engine). You should be able to run the engine at full throttle for 5 minutes or so if needed with no problem (if you have the right prop).
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
