SailNet Community - View Single Post - DIY Dinghy Lift at Transom Location
post #7 of Old 10-28-2012
pdqaltair
pdqaltair's Avatar
Re: DIY Dinghy Lift at Transom Location
Many davits are overly complicated because they try to mount the whole business on a deck flange, instead of allowing the pipes to pass through and be secured inside, like a keel stepped mast. That is how they are on a PDQ 32; very simple, large diameter tubing passes through the transom via a flange and is secured to an inner transom at a second flange.
Sail Delmarva: All Triced-Up
A 6:1 tackle with cam cleats is very easy and allows for a rest. The cam cleats are backed up with horn cleats and the dingy triced-up as well.
Sail Delmarva: Better Purchase for Dingy Davits
Given that you have a monohull, you will need higher davits and thus the pipe will need a higher angle and a bend, but this is one way to keep the fabrication quite simple. And simple is strong.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
