SailNet Community - View Single Post - How Hard To Push My Perkins
post #5 of Old 10-29-2012
amarinesurveyor
Re: How Hard To Push My Perkins
The Perkins Perama M-30 engine puts out 29 hp at 3,600 rpm, that is your maximum rpm. Usually you can run diesels at 75 - 80% of maximum rpm all day long. That would be 2,700 to 2900 rpm. You should also be able to run at full throttle for short periods if everything is right (cooling system, clean prop, clean bottom, etc.).
Brian
amarinesurveyor is offline
