SailNet Community - View Single Post - Seacocks
Thread: Seacocks
post #6 of Old 10-29-2012
Maine Sail
Maine Sail's Avatar
Re: Seacocks
Originally Posted by Ajay73 View Post
Thanks for the reply. If you open the seacock with the boat out of the water does that eliminate the need to use the drain/lube hole to drain water. In other words, is there possibly water in the seacock body that is somehow trapped and can only get out through the drain hole?
These seacocks are Apollo brand. Bought them at West Marine.
You have ball valves and they should ideally be drained.... Opening and closing does not always allow them the drain. It should, but does not always.. With tapered cone they do drain but with ball valves not always..
______
-Maine Sail / CS-36T
Maine Sail is offline
