SailNet Community - View Single Post - HMS Bounty in trouble...
post #44 of Old 10-29-2012
NCC320
Re: HMS Bounty in trouble...
A couple of other things to consider.
This boat was built as a movie prop. It is likely that the investors didn't build the boat to the same standards as a real sea-going ship...the original, even though is was built in another day, was likely more seaworthy. It was built in 1962 of wood, which also means that if it didn't get regular, expensive, and intensive upkeep, it was likely not all that seaworthy at this time vs. when it was newer.
If this boat was in CT/NY on Thursday, the storm was already on it's way. Given the storm size, which has been highly advertised, there was no way that the boat wasn't going to experience storm conditions, and possible hurricane conditions.
The boat had a lot of freeboard, and it is possible that while they may have intended to stay offshore of Cape Hatteras, the winds of the approaching hurricane would have been from east initially and they may have been gradually loosing ground from intended track due to excessive leeway, especially if engines weren't sufficiently powerful.
When you are in bad storms, because of way the waves and wind are attacking the vessel, it is often that you have to pick a course and speed other than intended to try to minimize the boat and crew from the pounding of the storm. Such change from intended course would be all the more important once the boat began to give evidence of taking on water.
90 miles off Cape Hatteras isn't that far off shore. Cape Hatteras isn't known as the Graveyard of the Atlantic for nothing.
NCC320 is offline
