SailNet Community - View Single Post - Winter Moisture Control
post #14 of Old 10-31-2012
Ajax_MD
Chastened
Ajax_MD's Avatar
Re: Winter Moisture Control
Originally Posted by TheTardis View Post
Are you using an adhesive to attach it? also, did you put it in the ports?
I put it in the ports and hatches. I did not use adhesive, I simply cut it snug and let friction hold it in. I will periodically pop it out to make sure that nothing grungy is growing behind it.
If you insist on attaching the insulation somehow, I suggest using small squares or strips of velcro, so that you can remove it when the weather is warmer.
I actually sail my boat, so I don't want any of this stuff to be permanent. It's unsightly, and in plain view. I only tolerate it because winter is coming on.
1981 Tartan 33 #168
Ajax_MD is offline
