SailNet Community - View Single Post - Winter Moisture Control
post #16 of Old 10-31-2012 Thread Starter
TheTardis
Rogue Musician
TheTardis's Avatar
Re: Winter Moisture Control
Originally Posted by BubbleheadMd View Post
I put it in the ports and hatches. I did not use adhesive, I simply cut it snug and let friction hold it in. I will periodically pop it out to make sure that nothing grungy is growing behind it.
If you insist on attaching the insulation somehow, I suggest using small squares or strips of velcro, so that you can remove it when the weather is warmer.
I actually sail my boat, so I don't want any of this stuff to be permanent. It's unsightly, and in plain view. I only tolerate it because winter is coming on.
I sail mine as well, however I want a more permanent and aesthetically pleasing (I am a girl after all) solution. I am installing the insulation and then placing a painted facade over it. Thought being that it will keep warm in winter and help keep cool in summer.
Brass Belle
'78 Pearson 30, #1099
TheTardis is offline
