SailNet Community - View Single Post - Experience's requested
post #4 of Old 11-30-2006
sailingdog
A lot also depends on your boat and what the hull is made of. If the hull is aluminum or steel, I'd go with the Marelon as the galvanic corrosion issues are fewer. While Marelon has come a long way, it also depends where your going to be sailing. In colder waters, I'd stick with bronze, as the galvanic issues are usually less aggressive and the Marelon, IIRC, doesn't do as well in low temperatures.
sailingdog is offline
