Re: bottom painting question
Originally Posted by paul323
Roll and tip; personally - and much to my surprise - I had good results with foam brushes. Cheap and disposable. I also used a small foam roller.
Foam brushes are surprisingly good for paint AND varnish. Be sure to get good ones though - the ones that look "foamy" - (lots of visible holes in the foam) are not nearly as good as the ones that have a more solid looking texture.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
