SailNet Community - View Single Post - Boy killed by lightning in our anchorage, what would you do?
post #24 of Old 11-02-2012
steel
Re: Boy killed by lightning in our anchorage, what would you do?
Originally Posted by PeterSailer View Post
What about steel sailboat?? if your inside would they act as a giant faraday cage? and if your on the outside of the boat? would the electricity run through the hole boat or hit the mast, shroud and stays and then use the shortest path to water??
Pierre
A full metal hull should do that. But don't forget about the mast top VHF antenna and the other wires going up there. There needs to be lightning arrestors on the antenna feed line and also on the power wires going to the lights. Else the surge will just come in through there and spread in to the whole electrical system.
As for the wheel and tiller, they should be electrically connected to the ground that the mast uses. This ensures that everything is at the same potential and there isn't a different voltage at your mast, rigging and lifelines than there is on your wheel or tiller.
steel is offline
