SailNet Community - View Single Post - 1984 c&c 35-3
Thread: 1984 c&c 35-3
post #33 of Old 11-02-2012
chef2sail
chef2sail's Avatar
Re: 1984 c&c 35-3
With the correct tension on your backstay adjuster and the correct rake this wont be a problem.
I didnt realize that there was a problem with the tank vent. Never affected our boat. However if you should ever redo your tank I would suggest you use nothing less than a 3/4 line vent. The more air in the holding tank the more good bacteria the less the smell. Also helps to only use fresh water also
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
