SailNet Community - View Single Post - Aluminum toe rail leak?
post #10 of Old 11-04-2012
hellosailor
Re: Aluminum toe rail leak?
I don't know what PSC does, or did on that model. If they did use adhesive plus bolts, it shouldn't need to be opened again. Shouldn't be leaking.
Are you absolutely positive that is where the leak is, as opposed to that being the place where the water is showing up on the interior, perhaps after running across the underside of the deck or down from another spot?
I can't see $40k to open the deck and close it up again, are you saying PSC actually quoted that to you? Or a yard did? reed suggested a price for removing the *entire* deck from the hull. That gets way more complicated than just replacing one rail, rebedding one side. And since that's a labor intensive job and labor rates are so variable...Why not get a quote instead of a web guesstimate?
hellosailor is offline
