SailNet Community - View Single Post - Making a Rudder
Thread: Making a Rudder
post #1 of Old 11-05-2012 Thread Starter
Rxboat
Making a Rudder
I have a 15' sailboat with an old rudder that is totally shot. The old rudder was fiberglass over plywood. So I copied the old one as a template onto a piece of 3/4" high quality plywood, cut out the pattern and shaped the wood. Now I am ready to put a layer of fiberglass over the plywood. Once that is done I will need to sand it smooth and apply some sort of protective finish, probably a good marine paint. I am not excited about using GelCoat since it is tricky to work with and to try and get a good result the first time,as well as the fact that it is expensive and I only need a small quantity anyway. Will a marine paint suffice to protect the new rudder from water under light sailing conditions and useage? The boat will be kept on a trailer except when I'm day sailing.
Rxboat is offline
