SailNet Community - View Single Post - Winter Moisture Control
post #23 of Old 11-05-2012
miatapaul
Old enough to know better
Re: Winter Moisture Control
Originally Posted by Jgbrown View Post
I'm surprised so many boaters like those oil filled heaters. I hate the bloody things.
My dad bought me one, and it works OK at night(I use it at 700watts and the proper electric forced air heater at 600watts to keep the boat fairly evenly heated).
However, I find that it smells a bit, and doesn't warm the boat nearly as well as the one that moves some air, in addition the humidity stays much higher with only the oil filled one.
The worst parts of the oil filled heater is its tendency to burn things, I burn myself on it at least once a day, or melt a plastic bag onto it or something.
By contrast, the Caframo(re-branded by west marine with fewer fan speeds, the original is nicer.) helps keep my boat dry, warm and isn't prone to burning things.
I would have the oil filled heater checked. I have seen several and none of them even on high would melt a plastic bag. On 700 watts you should be able to touch it. There also should be no smell from it, at least not after a short brake in time.
miatapaul is offline
