SailNet Community - View Single Post - Anybody know of coaxial thru-deck connector?
post #16 of Old 11-05-2012
miatapaul
Old enough to know better
Re: Anybody know of coaxial thru-deck connector?
The other issue is that WiFi antenna connections do not like long cable lengths and should be kept short as possible, then add connections in between I think you are going to wind up with a weak signal. Normal recommendation is not to go over a few feet that is why they almost always have the antenna physically attached to the units. . My plan is to go with a Ubiquiti Bullet WiFi bridge, as it attaches directly to the antenna and uses twisted pair for the connection and you are good for a 100 meters and that will be long enough anything I plan on ever owning!
miatapaul is offline
