SailNet Community - View Single Post - easier diesel bleeding
post #12 of Old 11-06-2012
bristol299bob
bristol299bob's Avatar
Re: easier diesel bleeding
Lostatsi, I'm intrigued, are you saying you can bleed the system without opening any bleed screws? I've never heard of this.
If I understand the concept correctly:
- provide positive fuel pressure via an electric fuel pump
- Use WD 40 to start the engine
- the engine will draw air and fuel through the fuel lines, essentially bleeding itself through the injectors.
Is that correct?
bristol299bob is offline
