SailNet Community - View Single Post - Steering Cable Tension Estimate (no book)
post #1 of Old 11-07-2012 Thread Starter
HighFly_27
Laugther is Good Medicine
Send a message via AIM to HighFly_27 Send a message via MSN to HighFly_27
I do not have a book and not likely to find one for -- 1970 Islander 37, MS, Hull # 3096
I was looking at the rudder assembly to see what I need to do to drop the rudder down. The rudder has about 2 feet busted off it and needs replaced or rebuilt. I have a habit of inspecting and recording values prior to the dissassembly of anything I repair.
I ran the wheel thru. and it's two turns .. lock to lock. I did not notice any change in hard spots (drag) during the check.
This is the Question.
What is the normal tension of the steering control cable as a norm. I think my cables are loose. I moved them back & forth between 16 inches of distance between two pulleys. I could deflect the cable a 1/2 inch or so. I did not take exact measurments. I knew I needed some (cable tension) information before I made an adjustment.
Avery
HighFly_27 is offline
