SailNet Community - View Single Post - Running a portable generator at an angle of heel
post #9 of Old 11-07-2012
mitchbrown
Re: Running a portable generator at an angle of heel
I have an EU1000 and my dock neighbor has 2000. the 1000 is an excelent unit as well as is the 2000 the 1000 is much quiter than the 2000, probably half as much noise. It is much lighter and smaller and that may be an issue if you need to stow it onboard. Mine fits nicely in a lazeret. The one thing you should know about the inverter generators is they split the voltage between the neutral and hot wire so depending on what you plan to run you may need to modify the output. I can tell you how if you are interested.
mitchbrown is offline
