SailNet Community - View Single Post - Running a portable generator at an angle of heel
post #19 of Old 11-08-2012
chef2sail
chef2sail's Avatar
Re: Running a portable generator at an angle of heel
I will smell gas in the cabin if I fill up my gas tank and spill some on the top of the tank. However it looks like hunter purpose built a shelf in the aft lazarette for the gas tank for the ob...
Not a good thing. When that gas you spilled evaporates it goes where? If the lazzaette is not sealed and does not vent overboard, please dont use it. Thoise fumes may make there way to you biilge/ engine compartment/ cabin and a spark may set them off. Look at gasoline storage just like you would propane. Not an expert, but is gasoline may actually be more explosive. I am sure someone her will let us know?
Its the fumes from the gas which are explosive. Thats why older boats like my Islander 28 which had an atomic 4 had a blower which I ran for 2 minutes before starting it.
The eu2000 is not much larger than the 1000. It is light, compact and eeirely quiet and very efficient. 46 lbs
Honda EU1000iA Generator (1000W) - Steadypower.com
Honda EU2000iA Companion Generator (2000W) - Steadypower.com
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
