SailNet Community - View Single Post - Steering Cable Tension Estimate (no book)
post #10 of Old 11-08-2012
msmith10
Junior member, rest old
msmith10's Avatar
Re: Steering Cable Tension Estimate (no book)
That's your emergency tiller. The tiller delam is minor. Just epoxy and clamps. That access port is the right one. You can open that with a large pair of pliers-stick the ends of the handles in and turn, use a large screwdriver between the handles if you need leverage. The cables look OK. As I said above, just check them for frayed strands. If there aren't any, don't need to change them.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
