SailNet Community - View Single Post - Water in oil
Thread: Water in oil
post #1 of Old 11-08-2012 Thread Starter
ultimatesailer
Angry Water in oil
On a Universal diesel 5411 with water in the oil, what is the best way to proceed? I have taken the raw water pump off and put it on tap water pressure and no leaks. I have looked at the high elbows on the exhaust and no water is back flowing. I have replaced the small plate gasket under the timing cover. I have replaced the head gasket and shim. Still getting water in the oil. Changed oil 7 times so far. I was going to remove engine and take off the oil pan and put tap water pressure on the cooling system to see if I could determine underneath where the water is coming from. Anyone else ever deal with this issue? Tkx
ultimatesailer is offline
