SailNet Community - View Single Post - Winter Moisture Control
post #48 of Old 11-08-2012
Minnewaska
Re: Winter Moisture Control
Originally Posted by amarinesurveyor View Post
.....when you heat the air it reduces the humidity.
That's not exactly correct. The higher the temperature of the air, the more moisture is can retain as humidity. Condensation occurs when the air is saturated with moisture and can't hold any more. Heat the air and it can hold more water, but its still there.
Its super cold air that can't hold much humidity.
Jeanneau 54DS
Minnewaska is offline
