SailNet Community - View Single Post - Voltage tester idea
post #6 of Old 11-08-2012
jorn85
Re: Voltage tester idea
Yes it will work but you will not get accurate reading from your meter because it is not directly connected into the batteries. You should remove the batteries for good readings because when you do this method you will get a small voltage drop from the batteries....
jorn85 is offline
