SailNet Community - View Single Post - Running a portable generator at an angle of heel
post #58 of Old 11-09-2012
propellanttech
Re: Running a portable generator at an angle of heel
Originally Posted by mitchbrown View Post
you people that are using either the 1000 or 2000 to run your onboard battery charger should take a look at the output of your charger It is probably pretty low since the input voltage on the AC side is only 65 volts. As i said in an earlier post the honda generators split the voltage between the neutral and hot leads and a mod is required to make things right. Its a simlpe matter of bonding the ground and neutral wire.
I would love to see a wiring diagram to this you speak. I'm planning to use a Honda 2000 and was going to wire it to the shore power connection.
You can PM me if you wish. I think I have enough posts to see it.
James L
propellanttech is offline
