SailNet Community - View Single Post - Refrigeration Conversion
post #10 of Old 12-03-2006
sailingdog
The "Pelletier" effect coolers are useless in really hot weather, as they can only cool a certain amount from the ambient temperature. They are also hugely inefficient. Using a "walmart" refrigerator and inverter is probably not a great idea, as the refrigerator is probably not insulated well enough for use on a boat—most small refrigerators make the assumption that they'll be used in a controlled climate area, and a boat is generally not one. A truck, like the one that Gregpecaut, can afford to run the A/C, which is often not the case on a sailboat, if it even has A/C at all.
Also, you have the inefficiency of converting the DC to AC using the inverter...if you don't think they're inefficient, just touch one that's been running a while and see how hot it is... that heat is electricity that has been converted.
Best small refrigerators for use on a sailboat are probably the Engel "Swing compressor" units. I've used one and they're very efficient. Most are top-loading designs, which helps keep the cold air inside the box when you have to open it.
sailingdog is offline
