Old 12-03-2006
sailingfool sailingfool is offline
ASA and PSIA Instructor
Mike,
(..I'd pay a pro to do this...). See if you can get a hydraulic auto jack under the engine, then remove all bolts and the drive shaft, and raise the engine and see if that gives you enough access. If not, try locating the jack on a plank that would allow you to pull the engine out.
