SailNet Community - View Single Post - Cleaning Hull in the water
post #34 of Old 11-12-2012
Fstbttms
I don't discuss my member
Fstbttms's Avatar
Re: Cleaning Hull in the water
Originally Posted by Minnewaska View Post
I could run the genset to power these, but I would have to be that much more careful with exhaust. It should not be a big problem if clocked downwind on the hook or mooring.
Most commercially available gas-powered hookahs have a simple snorkle air intake that draws air from about 3' above the unit. Assuming you had your electric unit on deck, that would likely be more than high enough to be out of any exhaust you might make running your genset.
Fstbttms is online now
