SailNet Community - View Single Post - Starting an M-25 on a pallet
post #1 of Old 11-12-2012 Thread Starter
Hi all!
I just bought a great looking 1986 Catalina 27 Tall Rig. She doesn't have an engine installed but came with a Universal M-25 diesel strapped to a pallet that the guy purchased from Trans Atlantic Diesels in Virginia. The forum won't let me post pics of the engine because I only have 6 posts so far.
Anyway, I'd really like to start the engine before I put in into the boat, and I'm just wondering what steps I should take to start it while its on the pallet?
Here's what I'm thinking:
  • Check fluids (coolant, oil, transmission)
  • Connect wiring harness on engine to instrument panel
  • Connect to a battery
  • Connect a line from the inlet side of impeller housing into a bucket of cold water
  • Connect a fuel line from a tank to the engine
  • Bleed the injectors
  • Start the engine!
So my question is.... What am I missing? Can it hurt the engine in any way to be run like this? Is there any problem with shifting into gear while its sitting on a pallet? What do I need to do, if anything, with the exhaust riser, should I hook a hose on there and stick it in a bucket of water?
I'm familiar with regular maintenance on diesel inboards but I've never tried to do this before and I've never installed an inboard.
I like the way the engine just plugs into the instrument cluster, it seems much more simple than other setups I've seen. Any tips that you may have would be really appreciated!
Ralph Jr.
rejjr7 is offline
