SailNet Community - View Single Post - Running a portable generator at an angle of heel
post #68 of Old 11-12-2012
Maine Sail
Maine Sail's Avatar
Re: Running a portable generator at an angle of heel
Gottch Maine,
I wasnt splaining myself very well. When I use the eu2000 I have to charge I ws only see 8 amps my Victron ...when I ran it through my shorepower and used my Mastervolt carger I saw 60 amp charge on the Victron. Usually at 2700 rpm ogn the enhine I am seeing 60 amp in on thre Victorn when the battery banks are depleted past the 85% mark.
Do these values make sense? Are they OK?
Dave,
Are you running the Mastervolt battery charger off the Honda and only seeing 8A or are you using the generators 12V output to charge and seeng 8A?
Your Honda should easily drive your Mastervolt charger to it's full rated output..
______
-Maine Sail / CS-36T
Maine Sail is offline
