Old 11-12-2012
Fstbttms's Avatar
Fstbttms Fstbttms is offline
I don't discuss my member
Fstbttms is on a distinguished road
Re: Cleaning Hull in the water
I have cleaned my hull by dragging a cheap tarp under it ,letting the poly tarp float up against my hull, then pouring a gallon of bleach in it and leaving it overnight. Next day all growth fell off. Works for weeds but not barnacles.
At sea, one can pull a rope under your forefoot and saw it back and forth across the hull working your way back to the keel, then doing the same from the keel to the skeg. Doesn't get everything, but removes a lot, if the growth is thick and heavy.
Both somewhat effective methods if you don't care about the environment or your anti fouling paint.
"Clean bottoms are FastBottoms"
