SailNet Community - View Single Post - Running a portable generator at an angle of heel
post #70 of Old 11-12-2012
Minnewaska
Re: Running a portable generator at an angle of heel
I connect the Honda via adaptor to the shorepower inlet on my boat. Mastervolt charger is connected to AC side of the Blue Sea Panel so yes I see 60 amp at bulk.
The 8 amp rating was from the Honda literature and must come from the generators 12 volt outlet which I rarely use at all.
dave
Chef,
The 8amp output of the Honda is at 110v, not 12v. Roughly speaking, it would be capable of 10 times the amps at 12v. amps x volts = watts.
Essentially, your battery charger is making this switch.
Jeanneau 54DS
Minnewaska is offline
