Old 11-13-2012
SlowButSteady's Avatar
SlowButSteady SlowButSteady is offline
Senior Slacker
SlowButSteady is on a distinguished road
Re: Frozen lamp oil (Paraffin)
Tubular lanterns (cold-blast and hot-blast lanterns) are much more efficient at producing light than are "dead-flame" lanterns. Many think they look "old-fashioned", but if you want light from a flame, they're the way to go. Kosmos-type lanterns are also very good.
From the W.T. Kirkman Lanterns website:
Q: What type of fuel can I use in a tubular lantern?
A: Standard Lamp Oil, Synthetic Kerosene, or Kerosene Substitute are recommended for use indoors. Clear K-1 Kerosene with a flash point of 124 to 150 degrees is recommended for outside use.
The approved fuels for indoor or outdoor use in Tubular Lanterns and Flat Wick Oil Lamps are:
1. Lamplight Farms® Clear Medallion Brand Lamp Oil, (#60020, #60003 aka #6300, #60005 aka #6400, and #6700 Only ) Flash Point: 145 Degrees Fahrenheit
2. W.M. Barr & Co. Klean-Heat® Kerosene Substitute (#GKKH99991, 128oz, sold by Home Depot SKU #391-171) Flash Point: 145 Degrees Fahrenheit
3. Crown® Brand Clear Lamp Oil (#755946) Flash Point: 141 Degrees Fahrenheit
4. Genuine Aladdin® Brand Lamp Oil (#17552, 32 oz., and #17554, 128 oz.) Flash Point: 141 Degrees Fahrenheit
5. MVP Group International Florasense® Brand Lamp Oil (#MVP73200, 64oz. and #MVP73201, 32 oz., Sold by Wal-Mart ) Flash Point: 142 Degrees Fahrenheit
6. Recochem Clear Lamp Oil (#14-573, 710mL, Sold in Canada) Flash Point: 124 Degrees Fahrenheit
The approved fuels for outdoor use in Tubular Lanterns and Flat Wick Oil Lamps are:
1. Non-Dyed (Clear) Kerosene with a Flash Point Between 124 and 150 Degrees Fahrenheit
2. Sunnyside® Brand 1-K Kerosene (#700G1, #80132, #801G1, #801G3,and #801G5) Flash Point: 125 Degrees Fahrenheit
3. Coleman® Brand Kerosene Fuel (#3000000270) Flash Point: 130 Degrees Fahrenheit
4. Crown® 1-K Fuel Grade Kerosene (#KEM41, #KEP01, #KEP25, #KEM05) Flash Point: 150 Degrees Fahrenheit
5. Crown® Citronella Torch and Lamp Fuel (#CTLP01, #CTLP02, #CTLP48) (OUTDOOR USE ONLY, cut 50:50 with kerosene to extend wick life.) Flash Point: 141 Degrees Fahrenheit
6. Tiki® Brand Citronella Torch Fuel (OUTDOOR USE ONLY, cut 50:50 with kerosene to extend wick life.) Flash Point: 145 Degrees Fahrenheit
NOTICE: Dyed kerosene or lamp oil will eventually clog the wick and inhibit proper operation. It can also permanently stain the lamp or lantern.
If you purchase kerosene from a gas station, make sure that it is from a "blocked" pump so that it is clear and not dyed red.
(Un-blocked kerosene pumps by law must dispense dyed kerosene which will clog lantern wick, and cause it not to burn properly.)
FUEL SOURCES:
Standard clear lamp oil (Lamp Light Farms Medallion Oil,) is available nationwide at: Target, K-Mart, Ace Hardware, True-Value Hardware, Sentry Hardware, and HWI Do-It Centers.
"Klean-Heat" Kerosene Substitute is available at or through most hardware stores and home centers including: Home Depot, American Eagle, Coast to Coast, Ace Hardware, True-Value, and HWI Do-It Centers.
Genuine Aladdin Brand Lamp Oil is available from Aladdin Lamp Dealers nationwide.
NOTE: DO NOT USE PARAFFIN OIL IN TUBULAR LANTERNS WITH 5/8" or LARGER WICK. (Use Paraffin only in lamps with 1/2" or smaller wick.)
NOTE: DIESEL, BIO-DIESEL AND OLIVE OIL ARE NOT SUITABLE SUBSTITUTES FOR ANY OF THE APPROVED FUELS AS THEY HAVE A FLASH POINT OVER 200 DEGREES FAHRENHEIT
LET'S GET SERIOUS ABOUT GUN CONTROL, NOW!
