SailNet Community - View Single Post - Keel Fix help
Thread: Keel Fix help
post #12 of Old 11-14-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Keel Fix help
Hello's method sounds pretty effective but I'd change one thing - the first "scrubbing layer" would be a lot easier if it was epoxy resin instead of filler. It would give the same, or better bond for subsequent layers.
Alternatively, going over the keel with a wire cup brush in a small grinder would clean off the oxide layer - lead stays "bright" for quite a while, unlike iron & aluminium so you'd have time to roll on a coat of resin to seal it before a problematic oxide layer formed.
SloopJonB is online now
