SailNet Community - View Single Post - Perkins 4-108 Fuel Injector Pump Leak
post #9 of Old 11-15-2012
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: Perkins 4-108 Fuel Injector Pump Leak
Originally Posted by Letrappes View Post
I'll check for diesel in my oil. If I have it I'll figure out how to get the girl injector pump out and have it rebuilt local.
Frankly, I'd have the oil analyzed if you have any question at all. Once the seals go around the throttle shaft, they usually have also gone/are going around the drive shaft as well (as I discovered). And it seems that all of them go somewhere in the range of 3000 to 3300 hours.
As long as some lamo hasn't installed an over sized water heater under the head of the port quarter cabin berth, you can get to the pump through the inspection port there if you are something of a contortionist. You'll need an Allan wrench socket with a long extension to get to one bolt on the back-side of the pump. It's a real chore.
Good luck!
svHyLyte is offline
