SailNet Community - View Single Post - Voltage tester idea
post #17 of Old 11-15-2012
Maine Sail
Maine Sail's Avatar
Re: Voltage tester idea
Originally Posted by SlowButSteady View Post
Actually, I'm in the process of upgrading some of the wiring on the boat right now. The little plug-in meter is being replaced with a hard-wired one (and an "(ON)-OFF-(ON)" toggle switch, so I don't have to switch the master switch back and forth to test both banks). However, I am going to run heavier gauge wire to all the plugs to avoid voltage drops.
The volt meter should ideally be run directly to each battery with its own wire and should not pull off the "panel". This keeps the monitoring wires free of loads thus no voltage drop other than the mA to power the LCD of the meter which means squat to the wire. Your meter won't have the resolution to even see the load of the volt gauge in terms of volt drop..
______
-Maine Sail / CS-36T
Maine Sail is offline
