SailNet Community - View Single Post - Retrofitting Tiller to Wheel Steering
Old 11-15-2012
cookwithgas's Avatar
cookwithgas cookwithgas is offline
cookwithgas is on a distinguished road
Re: Retrofitting Tiller to Wheel Steering
Denise:
You are thinking all the right things - thanks. After thinking about it a while my plan is to modify the wheel to work like a quadrant. Yes, I do have the two extra pulleys that I took off the donor boat. A new quadrant runs from $500 to $900. This seems silly since the entire assembly was $100 including the wheel! Yes, the rudder came off the donor boat but it is completely different and I'm going to do this retrofit with my boat in the water so I'll stay with my current rudder and tube. I have a mill and lathe at home in my garage so machining a shim should not be a problem - also cutting down the aluminum wheel should not be a problem. The diagram you posted helps me understand what I need to do. The only trick will be to make a "split" bushing because I can't remove my rudder tube for this project.
I will post pictures as I make progress. Thanks again.
