SailNet Community - View Single Post - The Complete Overboard Bag - Rate It
post #4 of Old 11-16-2012
zz4gta
I don't discuss my member
zz4gta's Avatar
Re: The Complete Overboard Bag - Rate It
The contents are good. Same bag could be brought onboard an airplane everytime you fly (just add a parachute). Lots of stuff but chances are you'll never use it. Even if you go over.
All waterproof:
EPIRB/PBL with GPS
VHF
whistle
visual signal device.
That should cover 90% of all people sailing. Offshore (which I'm assuming this article was about) a lot more stuff is nice. But things like a first aide kit and liferaft repair, need to be already packed into your liferaft before it inflates. So you throw it over, and it's already there. And that thing is going to be heavy. 1 gal of water is 7 lbs. This is the reason that racing regs make you place a liferaft in a place that you can deploy it in xx amount of seconds. Those things are like 70 lbs and you can't lift them up companionway steps in a seaway.
Merit 25 # 764 "Audrey"
zz4gta is offline
