SailNet Community - View Single Post - Lesson from newbies-how not to install a roller furler
post #15 of Old 11-18-2012
TakeFive
TakeFive's Avatar
Re: Lesson from newbies-how not to install a roller furler
Even if you had removed the cotter pins, you may have still had a problem. Whenever you turn the turnbuckle, you should also use a wrench to prevent the backstay from rotating. Based on your description, it sounds like you were not doing this. If you were, you would have noticed right away that the cotter pins were preventing proper rotation of the turnbuckle.
There should be a flat spot above the threads to engage the wrench. Often this is stamped with a number, which I believe is the size wrench (in mm) that you need. With an elevated turnbuckle placing the wrench can be very awkward, because you need to reach even higher above the turnbuckle. I use a step stool on the cockpit sole to get up high enough, and it's still awkward.
You also need to use a wrench for shrouds as well, but those turnbuckles are much easier to reach.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
