SailNet Community - View Single Post - what type battery and size are you using on your spirit
post #5 of Old 11-19-2012
windyway
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
Re: what type battery and size are you using on your spirit
Originally Posted by tschmidty View Post
Where exactly is the battery located on your boats? mine seems to be under the front v berth but figured I would see what everyone else is doing.
Thanks.
Batteries are fairly heavy, use the weight to your advantage. The front V berth is a good spot it will more balance the boat when the cockpit has more people in it or you have a heavy engine. But have it on the opposite side that the engine is on. Boats like airplanes have to have a balanced C of G. for optimum sailing performances. The lower the battery is in the hull for instance, the more help it will provide to counter act heeling.
windyway is offline
