Re: Orientation of Flexible Holding Tank
We used to have an old vetus flexible tank before we reconfigured our whole system. One of the issues was when it was pumped out it would sometime collapse on itself somewhat preventing evacuation fully.
Also when installing this make sure it is supported with some kind of strapping system ( with soft sided restraints to the hull ot it will move around when partially full as it could break, put strain on the valves. Remember...1 gallon of water =12 lbs.
dave
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
